clicking
  • patdog76
    • May 2006
    • 14
    clicking
    I have a 2000 air natique, i launched the boat yesterday and all it would do is click when i tried to start it. i baught a brand new batt. and new starter and it is still clicking and will not turn over. Any one have an idea of what it could be. Thanks for any help.
  • SGY
    • 990
    RE: clicking
    Sounds like a starter relay issue. Pretty common with the GT-40.
    • core-rider
      • Feb 2004
      • 1359
      • Huntsville, AL
      • 2003 Black SANTE
      RE: clicking
      Starter relay sounds right, but make sure all connections are good and corrosion free. If any of your battery to starter connections are just a tad bit loose it could cause a similar issue. Not enough amperage will flow causing the starter to just click instead of engaging. Check the grouds also. A loose or corroded ground can cause all kinds of weird problems.
      Jason
      All black 2003 SANTE
      -- Southern Fried --
      • patdog76
        • May 2006
        • 14
        RE: clicking
        all that works fine. I put a new starter relay in and it is still just clicking. so now i have a new starter, starter relay, new battery and still boat will just click. any other suggestions. i appreiciate any idea out there.
        • Jesse1
          • Sep 2004
          • 78
          • East Texas
          RE: clicking
          Make sure that new battery is fully charged. I'd put a charger on it just to be sure.
          • Roddbod
            • Sep 2004
            • 116
            Make sure to check out your main wiring harness plug. I had the same problem in my 04 SAn and that is all it was.
            • surroundsound64
              • Jul 2005
              • 2147
              • Longview, TX
              • 2018 230 1981 Ski Nautique
              Sounds like a low batt. since everything else is new.
              Maybe bad grounds.
              2018 SAN 230
              1981 Ski Nautique
              Sold - 2011 Sport 200V
              Sold - 2000 SAN
