SAN 220 walk through
  • Cram
    • Jul 2016
    • 59
    • PA
    • 2006 SAN 220TE
    Click image for larger version  Name:	image.jpeg Views:	1 Size:	69.1 KB ID:	514633Click image for larger version  Name:	image.jpeg Views:	1 Size:	49.2 KB ID:	514634
    Just finished my last winter project. With help from member write up I was able to plan out my new walk through. The pictures aren't the best but I wanted to take a few shots of the final product.
  • a.klos
    • Dec 2007
    • 213
    • North Jersey
    • 2002 Super Sport
    Looks like newer Nautique! What was the cost of the seadeck? I was thinking about doing it on my boat. Take a better picture, please.
    • Cram
      • Jul 2016
      • 59
      • PA
      • 2006 SAN 220TE
      I paid $350.00 for the engine cover, and two other smaller pieces from Gator Step. They matched my current flooring perfectly. I will get some better pictures today.
      • Cram
        • Jul 2016
        • 59
        • PA
        • 2006 SAN 220TE
        Better pictures added.
        • ScooterMcgavin
          • 1542
          • 2014 SAN 210 TE
          Nice work Cram, that looks great !
          1989 Sport Nautique
          • Mike Fenton
            • Apr 2017
            • 71
            • Addis, Louisiana
            • 2014 G23
            I like that. I have a 07 220 and my motor cover has a small tear and was going to replace skin but I like this idea. What did you do about the pull up hatch to access the warming tray?
            • markj
              • Apr 2005
              • 1194
              • NorCal
              Wow! That looks really good.
              • Cram
                • Jul 2016
                • 59
                • PA
                • 2006 SAN 220TE
                Markj, thank you for the comments. I've had the boat out 5 times so far. What a difference it is having the decking to walk on instead of the vinyl.
                • 8urchvy
                  • Oct 2014
                  • 176
                  • La Verne
                  • 2007 SANTE 220
                  Wow!!! That looks so trick! Does the 2006 have the ski rope access for the warming drawer? I have a 2007 and you can access the ski ropes by either opening the warming drawer hatch or lifting a mini-compartment at the top back of the cover.
                  • Cram
                    • Jul 2016
                    • 59
                    • PA
                    • 2006 SAN 220TE
                    8urchvy, I don't have the use of that door anymore. I gave it up to have the walk through. Don't regret it at all.
                    • Tidrow55
                      • Aug 2012
                      • 60
                      • Roanoke, VA
                      • 2007 SANTE 220
                      What did you have to do to add the seadeck? Just remove the vinyl and padding?
                      Thanks!
                      • Cram
                        • Jul 2016
                        • 59
                        • PA
                        • 2006 SAN 220TE
                        Tidrow55
                        When I removed the vinyl and padding the fiberglass was unfinished and stepped down about an inch from the two storage hatches. I bought 3/4'' poly board that I glued and screwed I to the hatch cover, I then routed the edges for a cleaner look. The Gator Step flooring was applied over the poly board.
                        • Kevin_B
                          • Jan 2008
                          • 313
                          • Greensboro, NC
                          • 2008 SANTE 220 1990 Sport Nautique
                          How much does the latch protrude up from the top of the finished flooring? Had you considered using a thicker poly board or would that had made it an awkward transition up from the fiberglass on the transom and behind the back seat. I'm currently in the middle of the project and would appreciate any insight. Your final product looks great!
                          1990 Sport Nautique
                          • yellowMIL
                            • Dec 2007
                            • 53
                            • charlotte
                            • 2006 San 220 TE 1990 SNCB
                            700+ Hours later still running strong
