FAE vs Nautique Surf Pipe
  • jondavis08
    • May 2016
    • 369
    • Battle Creek, MI
    • 2014 SANTE 210 2003 SANTE 210-Sold
    My 2014 210 was optioned without a Surf Pipe. This is a option that I personally feel I must have. The Nautique Surf pipe cost $825 vs the FAE option at $480. I think the Surf Pipe looks sharper than the FAE but for $345 more?? If I go FAE is the Flappers a good idea? Does the blended weld look that much better? The only time the pipe is seen is when it's out of the water. Does the look of it really matter?
  • Shockthis
    • Mar 2013
    • 302
    • Christina Lake BC
    • 2021 centurion ri245
    I don't think so. I have a FAE and I love it. I would buy a boat that had FAE or surf pipe over one that didn't .
    • Nick Heimer
      • Apr 2015
      • 82
      • Omaha, NE
      • 2005 SANTE 210
      I went without the flappers or the blended welds and don't have any regrets.
      I do agree the Nautique pipe is much better looking, but at that price I don't think I could justify it.
      • ScooterMcgavin
        • 1551
        • 2014 SAN 210 TE
        Click image for larger version  Name:	image.png Views:	1 Size:	1.03 MB ID:	507582Click image for larger version  Name:	image_35276.png Views:	1 Size:	687.2 KB ID:	507581
        I like the look of the Nautique pipe better also... That being said I couldn't justify spending that much more on it (almost double ). I went FAE and am extremely pleased by the function and look of the pipe, works very well. I did do the blended welds, it wasn't that much more and something I could justify.
        1989 Sport Nautique
        • Nick Heimer
          • Apr 2015
          • 82
          • Omaha, NE
          • 2005 SANTE 210
          Looks great. The blended welds do clean it up a bit more.
          • CMW
            • Aug 2011
            • 66
            • englewood co
            i got the nautique pipe... just seemed better... i like its looks...
            Click image for larger version  Name:	IMG_0086.JPG Views:	1 Size:	68.9 KB ID:	507624
            • markj
              • Apr 2005
              • 1194
              • NorCal
              I've had both and I would recommend the surf pipe. The surf pipe attaches better, looks factory and doesn't need the goofy brace kit that looks like an erector set. I also had trouble with my FAE partially slipping off the flange if I made hard turns. I later had a welder fab and powder coat a custom brace for mine which helped some.
              • vanhanbr
                • Mar 2014
                • 223
                • Wisconsin
                • 2008 SAN 210
                Is the surf pipe compatible with the 2008 210?
                2008 SAN 210
                1997 Sport Nautique
                • CMW
                  • Aug 2011
                  • 66
                  • englewood co
                  guess it depends on what you mean by compatible, my boat above is 2008 210 with surf pipe, it required a bit of work to install
                  • vanhanbr
                    • Mar 2014
                    • 223
                    • Wisconsin
                    • 2008 SAN 210
                    I just seen on nautiqueparts that it only was for 2014+. I really don't like the clunky looking bracket that attaches to the swim platform on the FAE. Would you mind explaining what is all involved to get the surf pipe to work on the older models?
                    2008 SAN 210
                    1997 Sport Nautique
                    • CMW
                      • Aug 2011
                      • 66
                      • englewood co
                      the hole pattern is different so you need to drill and fill a few holes, also the nautique surf pipe extends into the exhaust system by a couple of extra inches, so you need to adjust some of the rubber hoses... i'll snap some closer pics and post to try and explain better
                      • CMW
                        • Aug 2011
                        • 66
                        • englewood co
                        hole pattern pic, the pattern is similar but is off just enough that you'll have to drill some new holes
                        surf pipe extends into that rubber tube several inches so you'll need to adjust that.
                        • wakejunky
                          • 679
                          • Ca
                          • 2003 SAN
                          Does Nautique's surf pipe have a flapper? I know there has been some discussion about getting the flapper on the FAE kits. I opted out but, I'm not concerned.
                          • ScooterMcgavin
                            • 1551
                            • 2014 SAN 210 TE
                            No the Nautique surf pipe doesn't have a flapper.
                            1989 Sport Nautique
                            • jondavis08
                              • May 2016
                              • 369
                              • Battle Creek, MI
                              I did end up going with FAE instead of the Surf Pipe. In all it the look of the FAE didn't bother me since it's only seen on the lift or on the trailer. For 1/2 the price I opted to just go with it. I did not got with the flapper, the rep at FAE actually talked me out of the flapper. Hopefully will have the install done soon! High 50's and sunny in Michigan this weekend... we are tempted to take it out on the water for the weekend!
