we bought a used 2007 210 last fall with a new short block installed with all the previous 2007 PCM components attached ie intake manifold, heads, exhaust manifolds exc
It has had extremely high oil pressure since I have had it, and have had a bunch of oil leeks along with it ,timing cover oil pan ,intake manifold
Starts cold at 60 psi once you warm it up it sits at 55 psi when you start running it at 3000 rpm goes up past 80 psi on the boat gage and throws a fault code of high oil pressure
I put a manual gage on the motor and ran it up to 3000 rpm and it goes up to 120 psi
were running 20-50 weight oil same at I run in my 200
Any one seen this before or have any suggestions
Thanks
Jim
Thanks
Jim
