Doing some major work on the boat and need to replace the steering cable. I pulled it out yesterday and had to cut the cable before the nut to get it pulled through because the tube is way too small to get it through. I did some research and I'm seeing that most everybody is replacing the cable and running the cable outside the tube. I'm contemplating splitting the tube and then slipping the cable back into the tube.
03' SAN
03' SAN
