2016 g23 ncrs circuit fault
  • Whitetail15
    • Apr 2010
    • 603
    • Unknown
    • 2016 G23 H6
    Ncrs seems to work fine for surfing and regular driving. As soon as you pull out with full ballast trying to get to wakeboard speed, Circuit fault appears for ncrs. It happens almost every time, but still seems to work.
    Seems like almost an overload tripping the fault code.
    Any suggestions?
    2016 G23
  • xxrb2010
    • Jan 2014
    • 226
    • nc
    Can you give a picture of your link system that shows what you call a circuit fault?
    • Armour783
      • Jun 2016
      • 30
      • Bucks County, PA
      • 2016 G23
      Nautique is actually aware of this:
Name:	NCRS Actuator Fault.JPG
      When I reached my hand under the platform I could feel the tiny black spacers and they wouldn't rotate. They were very snug. Our dealer replaced the black spacers and tightened the bolt correctly (so that the black spacers could rotate freely) and the fault hasn't returned.
      Essentially it's an assembly problem. When the bolt is too tight it's causing an excessive load on the NCRS actuator, causing the circuit to overload and trip.
      2016 G23
      • xxrb2010
        • Jan 2014
        • 226
        • nc
        Great information,
        Is the fault message an exclamation point on the top left screen where the NCSR icon is located?
        • Whitetail15
          • Apr 2010
          • 603
          • Unknown
          • 2016 G23 H6
          I will tonight. After I take a picture. My bolt spins by hand and spacers are loose. So that is not the problem.
          2016 G23
          • Whitetail15
            • Apr 2010
            • 603
            • Unknown
            • 2016 G23 H6
            anybody else getting this error??
            2016 G23
            • Superbawn
              • Aug 2016
              • 25
              • Plymouth, Minnesota
              • 2016 SAN G23
              I've had this fault a number of times. I've never seen it while running at wakeboard speeds though. I have the fault happen if I'm plowing water for too long before I plane out with full ballast. I figured that the actuator couldn't force the plate down causing the fault. I will check my spacers and bolts when I get to the boat next and reply back and see if that theory fixes the issue. Thanks for the info Armour783!
              • thedude
                • Apr 2007
                • 451
                • SW PA
                Whitetail15 - did you figure out your NCRS issue?
                • Whitetail15
                  • Apr 2010
                  • 603
                  • Unknown
                  • 2016 G23 H6
                  I did. Sorry for late response. I replaced the ncrs accuator and never got the code again. Even though the original tested fine it must have been drawing too many amps under load and throwing the code. All is good.
                  2016 G23
