I've got a 2002 super air and Had the boat out today and ran fine across the lake and throughout a first rider. Then once the second wake boarder when I put the power to it to get on plane it revved high, almost like a prop cavitating. Also around 35 there was a pretty good vibration. Checked the prop it checked out with no dings and bends. Any one else have this problem? I'm praying its not the transmission slipping under load. If you slowly get to speed it gets there fine with no slipping or cavitating or slippage. Anyone had this problem before? Or ideas?
