How to get stains from SeaDek
  • Whitetail15
    • Apr 2010
    • 603
    • Unknown
    • 2016 G23 H6
    Has anyone posted safe cleaners for the SeaDek material. I layed my swim platform on a blanket in my garage to protect it only to find out it had a motor oil spot on it that was absorbed my the SeaDek. It is very small, dime size, but I want to get it out.
    2016 G23
  • Z man
    • May 2010
    • 26
    • Lake Hartwell, Georgia side
    • MasterCraft X15
    If you have some extra material to do a test on I'd try Totally Awesome on it...
    • Guntersville230
      • Aug 2015
      • 419
      • Guntersville, AL
      • 2015 SAN 230
      I have heard of people using "Simple Green" since it is enviro safe and non-toxic you can just rinse it off in the water the next time you go out...just a thought. I have tried one or two spots on my seadeck and it has seemed to work well.
      • wakerider107
        • 271
        • south
        https://www.seadek.com/documents/7.2...n%20SeaDek.pdf
        2012 SANTE 230
        • markj
          • Apr 2005
          • 1194
          • NorCal
          Every time I have an oil spill, I just pour some Comet on the spot and let it sit. The Comet tends to wick it out. Just keep applying it as needed. It'll come out for sure.
          • Neverenough
            • Sep 2012
            • 907
            • Ft. Worth Texas
            • G
            Warm water and mild soap works ok. I'm actually thinking about the brown seadek on next boat because of this. Gray seems to show more.
            • Bevostein
              • Jun 2008
              • 523
              • Frisco, TX
              Dawn soap is used to clean animals impacted by oil spills. Might give that a try before using something harsher
              • lucky7t
                • Mar 2011
                • 1306
                • Oklahoma
                • 2015 SANTE
                I second the dawn dish soap but I would get warm water put in spray bottle and add a few squirts of it and spray it on and wipe off with microfiber
                Current Correct Craft Boat
                Correct Craft Boats Owned
                • dixxy
                  • Apr 2015
                  • 136
                  • canada
                  • 2019 GS22, previous boat 2005 SV211
                  The guy that did mine told me to use a mild soap like dish soap and a brush.
                  I did have some bird dropping on the swim platform. ..ducks...so a fair size...after flushing it with water, I used a brush to really get it all out.
                  Sent from my SM-G900W8 using PLANETNAUTIQUE mobile app
                  • enzo thecat
                    • Aug 2010
                    • 221
                    • Lake Wawasee among other places
                    • 2026 G23
                    I get oil and grease spots out of things with WD-40. Spray it on and massage it with a soft toothbrush. Its thin ad will dissolve and dilute the oil. Then clean that up with Dawn and H2O
                    2016 G21 SupeAir.
                    • core-rider
                      • Feb 2004
                      • 1359
                      • Huntsville, AL
                      • 2003 Black SANTE
                      Sunlight will also help after cleaning. The only thing that seems to be impossible to remove is mustard according to my discussions with the guys at SC Wake last month.
                      Jason
                      All black 2003 SANTE
                      -- Southern Fried --
                      • XBIGPUN66
                        • Oct 2012
                        • 472
                        • Lake Mendota
                        • WI
                        We used Dr bronner's hemp soap with an upholstery brush. Then rinsed. Worked great on our gray sea dek.
                        Sent from my SAMSUNG-SM-G930A using Tapatalk
                        Ian S
                        • 8urchvy
                          • Oct 2014
                          • 176
                          • La Verne
                          • 2007 SANTE 220
                          I use Meguires vinyl cleaner
                          #39
