I am going to add a rear ballast system to by 2001 model year nautique. I would like to wire it into the factory wiring. The link to the wiring diagram is here http://www.planetnautique.com/Correc...ingHarness.pdf
My questions related to this project are as follows: 1. pump recommendations? 2. Since there is only a power and neutral does the switch on the dash automatically reverse the pump to go from fill to drain???? Most of the new wiring diagrams map out the fill and drain on a separate wire.
Thanks for your help in advance!
