I have 2006 220 Super Air. When using the factory fresh water flush system, is it normal for water to flow out from around the prop shaft?
Absolutely Normal. You have the Dripless shaft seal. Some water after the transmission cooler is routed to that seal and is used to keep the seal and shaft cool.2007 SANTE 220 - ZR 6 Engine (Bought 2015)
1999 Supra Launch (Bought in 2013)
1987 Supra Marauder - 454 big block (Bought in 2000 - Sold 2015)
