I just spent the day getting my boat ready for spring and in the process realized that the brake line from the master cylinder down the inside of the trailer frame is broken somewhere inside the frame. Brake fluid came running down the frame and out the hole where the line entered when I was bleeding the brakes. Does anyone have any words of advise for replacing this? I'd like to replace it with a hard line if possible. Fitting a rubber tube inside the frame comes with its own set of challenges as the hoes to get in and out of the frame are pretty tight. Not to mention the other drawbacks from rubber brake lines.
I am debating pulling the line out and having another one made. I am just worried I might not be able to get the new one back in without hurting it.
