I have a '97 Ski Nautique 196 with a GT-40 EFI. Boat has perfect pass. Boat has ran great the last 6 years I have owned it until last summer. Boat would start up great, we would then run 4-5 passes and engine would either completely shut off or would cut in and out eventually shutting off. Once this happened, majority of the time it would start back up and maybe run for another couple passes then would shut off again. Sometimes we could limp it back to shore, other times had to be towed. At this point (maybe 20 minutes in), engine would start up normally then shut off within 1 second. One time we put boat in it did this right from away, it would start up normally but immediately shut off.
What we have done:
Always run Startron fuel stabilizer
Tested battery, parts store said it was strong
Re-built alternator
Tested starter and that is fine
Replaced both fuel pumps
Any thoughts on what is going on?? Help much appreciated!
What we have done:
Re-built alternator
