Went to winterize my 2011 ZR450 yesterday and found oil in the bilge after backing the boat on the trailer in to the water. I started the engine briefly to see try to see where the oil was leaking from. Turned the engine off and checked the dip stick. There was no water in the oil, but the oil level was at the bottom of the hash marks on the dipstick. I started the engine again to see if I could see a leak. Long story short, the only place I could see oil leaking from was the oil filter, but what's concerning to me is that after only running the engine for 8-10 minutes the oil was barely touching the dipstick. It never lost oil pressure. I took the boat home and changed the oil. The old filter was screwed on tight and when I took it off the filter including the rubber seal looked fine. I couldn't see any leaks after filling the engine with oil, but wont have time to run the engine until Saturday.
Has anyone ever had oil leak from the filter with one of the remote filter locators? It didn't seem like enough oil was coming from the filter to almost empty the pan. Anyone have any thoughts?
