I just bought a 02 san with a ramlin trailer. Brakes don't work. Had no brake fluid and reservoir was rusty. I blew out lines and had every thing clear except reverse lockout. Reassembled bypassing reverse lockout but still no brakes. So where can I buy parts? Has disk brakes.
White Lake Marine is a Ram-Lin dealer. I am sure they can get the parts you need if necessary.
910.247.6201Please do not PM me directly asking for advice on how to repair your boat. While I would love to help everyone, I simply do not have time to respond to all of the inquiries. Please post your questions on the forum, so that all of our members have a chance to answer.
Item Part No. Options Unit Price Quantity Price
The Vault Trailer Wheel Bearing Protector, 1.980 UFP07502 $11.95 4 $47.80
Trailer Buddy Hybrid Oil for VAULT Hubs, 14oz. U-VHLS14 $8.99 3 $26.97
UFP DB-35 Disc Brake Unit - Silver Zinc Plated Rotors w/Aluminum Calipers UKIT25 $264.95 2 $529.90
I order this from Pacifictrailers.com. I don't know if you have the same calipers and rotors, but they had Kodiak and a few other types too. The kits came with all the bearings and seals too. I later ordered the master brake cylinder after seeing some of the corrosion that had accumulated in the bottom too.
02 ramlin is going to have drums. The cc/ramlins I have maintained use many of the same brake parts (minus coupler) from '88 through '99. Parts are readily available from places like Etrailer. Post a few pics of your hub/drum assemblies and take a few measurements, should be 12x2" hub/drums. Several backing plate/brake assy options in that size, I suspect the originals were dexters, at least on the pre-torsion ez lube axles.1990 Ski Nautique
NWCT
