Ongoing steering issues 196
  • TRST
    • Mar 2009
    • 44
    On going issue still not resolved. My steering binds and releases when going from right to left. only under load and only when turning right and then going back to the left. It kind of catches and then releases. I have replaced the cable, tilt helm and repacked the rudder. The only play I can "see" is in the connection between the rudder arm and clevis. The only things left are the clevis, tube, ball and socket bracket on the stern and the helm 1/2 of the rack up front.
    Any more ideas? I am about to order the clevis but I hate to keep throwing parts at this.
    2007 196 Limited Zero Off
  • ScooterMcgavin
    • 1551
    • 2014 SAN 210 TE
    Just throwing this out there but isn't there some sort or steering rack( or mechanism) that the cable feeds into under the dash behind the steering wheel? Maybe it's getting bound up there. I would suggest unhooking everything and try to move each part separately and individually to see if you can feel the bind. Move the rudder by hand with out the cable connected. Unhook the cable from the steering wheel and then turn the wheel both ways to see if you feel the bind. Then check your new cable make sure it moves freely. Just a thought
    1989 Sport Nautique
    • NCH2oSki
      • 1159
      • Maryville, TN
      • 2005 ski nautique 206 SE
      Mine did the same thing after I replaced the steering cable this spring. I found that the cable was in a bind going from the helm under the deck. I worked out the bend into a larger radius and so far so good.
      Prior Boats:
      1999 Ski Nautique GT-40
      www.skiersofknoxville.org
      • TRST
        • Mar 2009
        • 44
        It's extremely smooth on the trailer and it only reveals under load while underway. It did this before and after cable replacement. Things are pretty congested in the deck with heater hoses but that's a good idea to check the radius. Anyone know if it's normal to have some play in the clevis connecting the cable to the rudder arm?
        • JayG80
          • Dec 2006
          • 253
          • Santa Fe, TX
          • 2007 Ski Nautique 2002 Ski Nautique 1999 Moomba Outback
          Try adjusting the trim tab on the rudder. Loosen the 2 Phillips screws and pivot the small tab and tighten in another position. I know this solved the issue for me and a few others that I suggested it to. Please let us know if it fixes or at least changes the severity of your steering.
          • nukemustang
            • Sep 2014
            • 410
            • Summerville, SC
            • Current Boat: 2018 GS20
            Could the rudder be torque loaded?? I mean it is not directly centered behind the shaft when it is turned hard over and with you having the boat in reverse, it is causing a "suction" across the back of the ruder towards the bow of the boat. Just a thought since you said it happened before and after the parts swap. You mentioned it is smooth on the trailer, does it happen when you in the water but are not moving (i.e. boat in neutral and not underway) too?
            • TRST
              • Mar 2009
              • 44
              The rudder is adjusted and properly loaded. Not a neutral rudder issue. I'm still thinking the play in the clevis shouldn't be there.
              • jhersey29
                • Nov 2013
                • 330
                • Colorado
                • 1971 Correct Craft Mustang 1988 Ski Nautique 1992 Ski Nautique 1999 Ski Nautique
                Have you tried to load the rudder by human hands to reproduce the issue? 3 people. One on wheel, one on rudder and the third searching for the bind?
                Sent from my RM-877_nam_att_205 using Tapatalk
                • TRST
                  • Mar 2009
                  • 44
                  Just got this in the mail. Much beefier than original and has a bushing instead of just the shoulder bolt. The clevis was the only obvious slack/slop I could find in the system so I am hopeful that this will be the solution.
                  • ScrewPusher
                    • Feb 2006
                    • 77
                    • Isle of Wight County, Va
                    when you said you re-packed the rudder, did you remove the rudder, clean off all the old hard grease/crud, then re-install and use the grease gun to fill? I had a similar issue years ago on my 196 and once I pulled the rudder, cleaned it and the stubb tube and started greasing from scratch it worked great. Only happened at speed when you needed to be able to turn quickly.
                    • malcolmskis
                      • Aug 2012
                      • 2
                      • Los Angeles, Calif
                      • 1999 Air/sport Natique
                      Ok Guys, I have a 2000 sport with the same issues. Been in the shop 4 times. New cable, repack rudder, check helm. NOW I think I found it. The cover over the rudder
                      in the boat has been scraping the plastic that the carpet it glued too. I have wear marks on the bottom of the cover. I think the cover gets old and flex causing this. Then you
                      load the boat with gear in the trunk and it will flex. The cable bolt is the one. I have pictures too. Going to do a lake test tomorrow !
                      • j2nh
                        • Dec 2003
                        • 628
                        • Spread Eagle Wisconsin
                        You need to check the rudder assembly including the flange that holds the rudder. I have seen two of these cast flanges cracked and caused the whole assembly to move, slightly, under load. You can see the cracks on two sides of the flange base. I can't say if this is the root cause of the problem but it should be on your checklist. Let us know what you find.
                        2018 200 Team H6
                        2009 196 Team ZR 409
                        2005 196 Limited ZR 375
                        2003 196 Limited Excalibur
                        1999 196 Masters Edition
                        1987 ProStar 190
                          • 17183
                          There was a recall back in 2010 for cracked rudder ports like the one above.
                          http://www.planetnautique.com/vb5/fo...der-port-issue
                          • j2nh
                            • Dec 2003
                            • 628
                            The two cracked ports, one in the photo, were from 2005 196's. These were never recalled but should have been.
                            2018 200 Team H6
                            1987 ProStar 190
                            • TRST
                              • Mar 2009
                              • 44
                              No visible crack and the bolts are tight. I replaced the clevis but didn't get a chance to get out over the weekend. It's not like the steering is stiff it actually binds and then releases. It's fairly subtle and when it started I thought it was in the helm. And by repacking I mean I dropped the rudder, cleaned, replaced the packing material, reassembled and greased with the gun.
