Guys, looking for help to ensure I don't mess something up. I have a 2005 PCM Excalibur 5.7, v-drive, no heater or shower
I pulled both engine block drain plugs, both exhaust manifold drain plugs and a plug on the engine circulation pump. I want to fill with anti-freeze and thought after I put these plugs back in I could pull the hose off of the intake strainer and pour antifreeze into this hose (or have a tank of AF to pull from). Start the engine and have the antifreeze pulled/pushed into the block by the impeller. Then when thermostat opens wait for AF to exit the exhaust. I'd then have all hoses and block filled with AF.
Am I missing something that could cause me problems with this process?
Thanks
Thanks
