High Pitch Engine Noise
  • krustey
    • Apr 2015
    • 2
    • Houston
    • 2009 SANTE 230
    My 2009 SANTE 230 has a high pitch noise coming from the engine compartment; I can't tell exactly where it is coming from. It seems to occur around certain RPMs and especially when I pull back on the throttle. As long as I am accelerating it doesn't really make the noise. The noise occurs in neutral at certain RPMs, as well. I have read about a whistle noise created by air intake, but this does not sound like something caused by this phenomenon. The boat runs well without any other issues; the sound is just annoying to me. I purchased the boat last summer and it has always made the noise. Any ideas?
  • scottb7
    • Aug 2011
    • 2198
    • Carson City, Nevada
    I got an idea. Why don't you make a video?
    • d_nodixon
      • Sep 2008
      • 475
      • Hammond, LA
      • 2013 SAN 230
      What engine...my ZR6 does something similar when topping out and easing off the throttle
      Sent from my VS985 4G using Tapatalk
      2013 SAN 230
      2006 SSN 210 (SOLD)
      • swatguy
        • 1644
        • Midwest/ Northern IL
        • 2008 SANTE 210
        It's the fuel going down the fuel rail to the engine. Kind of sounds like jet engine /turbine/ high pitch whistle.
        • d_nodixon
          • Sep 2008
          • 475
          • Hammond, LA
          • 2013 SAN 230
          Sounds just as you describe...pretty sweet of you ask me.
          2013 SAN 230
          2006 SSN 210 (SOLD)
          • Kenv
            • Jan 2004
            • 1070
            • Texas
            Krustey....what will fix this is a spacer for under the throttle body. Had this sound with my 2010 226 343 and it took the sound away. There were several posts on this a few years back. Even a notice from PCM from what I remember. Mine purred like a kitten after the fix. No irritating whistle or whine...but still had good solid engine sound.
            • toomuchuv
              • Mar 2013
              • 190
              • Canada
              • 2014 SAN 230
              PCM sent me the part for free!
              "I'm on a boat........"
              • krustey
                • Apr 2015
                • 2
                • Houston
                • 2009 SANTE 230
                Attached is a short video where you can hear the noise. I tried to accelerate and decelerate to show the sound.
                • xrichard
                  • Aug 2008
                  • 671
                  • El Dorado Hills
                  • 2023 G23
                  It's hard to tell from the video, but I had a similar sound on my '08 343. It wasn't there when I first took delivery...maybe a couple of years before I heard it. I contacted PCM to get the spacer plate but never got a response. In any event, based on previous posts here, it's normal--but you can reduce or eliminate the noise with a spacer.
                  Previous boats:
                  2015 G23
                  2008 SAN 210
                  2002 XStar
                  1995 Sport Nautique
                  • toomuchuv
                    • Mar 2013
                    • 190
                    • Canada
                    • 2014 SAN 230
                    Yep..... thats engine whistle. The spacer under the carb will take care of that. Contact PCM
