Gt40 not turning over
  • rbalan
    • 328
    • Georgia
    • 2002 SANTE
    I have a 00 air/sport that does not turn over. I have had intermittent no start problems that lead me to think the starter relay may be at fault. I've replaced it to no avail and bypassed the safety lanyard. Everything works on the dash except ignition. Can a bad fuel pump relay(s) keep the engine from turning over? I do not hear them prime before trying to start, I'm lucky if I get a clicking sound.
  • a0128
    • Jan 2014
    • 423
    • Lake Oswego, OR US
    • 1999 Pro Air Nautique
    Sounds like you have two different problems going on at the same time 1) no fuel pump activity, 2) no starter activity.
    The HP fuel pump has a relay and will be disabled by a bad lanyard safety switch, but will not prevent the engine from turning over. The lack of starter activity and the fact that you are getting intermittent clicking noises is indicative of a bad starter solenoid, keypad going bad or both.
    Have you also checked the voltage on your starting battery?
    • rbalan
      • 328
      • Georgia
      • 2002 SANTE
      I haven't checked voltage yet, but blower, bilge pump, etc. seem to be operating normally. It seems like there should be enough to get a response from the starter.
      • brettmcox
        • Jan 2007
        • 284
        • Unknown
        i have something like that with my Gt40. I have replaced my Relay and my starter in the past 2 years. I am going to add a New Ground to see that fixes my issue.
        I am just getting a "CLICK" sometimes...
        I was told by Discount Ski that GT40 are know for having ground issues...
        2001 Super Sport - GT40 1986 SN2001 - 351 1973 Cobalt - 188/888 2014 F150 Screw 3.5 twin turbo 2011 Expy 2002 F150 SCrew 2001 F150 SCrew 1973 K5 (toy) 1995 Burb 3/4 454 1991 K5 Blazer (DD/Toy) 1987 Honda Accord 1978 Ford F100 1981 Merc Capri 1991 Honda Civic 2002 Ninja 500R sold...
        • azeus17
          • Feb 2008
          • 387
          • Grand Rapids, MI
          • 2022 GS22 - Coming in July Previous Boats: 1989 Sport Nautique 2002 SANTE
          Have the battery tested before you throw more money at it. Blower and bilge draw almost no amperage and will run normally without enough juice to turn engage the starter. You should, however, at least get a click. Either way, test the battery at Autozone, etc. Its free and will rule out at least one issue.
          • kend
            • Oct 2013
            • 193
            • DFW, Texas
            • current 2001 Air Nautique previous 1988 Sanger DX
            Yes, have the battery tested to make sure it has the cranking amperage first. Weak grounding (connection at battery or engine block) is very common because of humidity around any boat.
            Ken
            2001 DD Air GT40
            • brettmcox
              • Jan 2007
              • 284
              • Unknown
              Same here.... i replaced the battery.....
              • rbalan
                • 328
                • Georgia
                • 2002 SANTE
                I'll be checking the battery this weekend (it's only a few months old fwiw). Brettcox, I assume you are replacing the whole ground cable/ clamp?
                I have had issues with battery drainage, lanyards, and fuses the past couple of years, and it's given me fits. I'm really ready to get to the bottom of it.
                One other thing, should I hear fuel priming before trying to start?
                • 2001SAN
                  • Apr 2012
                  • 203
                  • Ireland
                  • 2001 Super Air Nautique 210, 1989 Fairline Corniche 31
                  Yes. You should hear them prime.
                  • Finnz
                    • Jun 2015
                    • 16
                    • Oklahoma City
                    • 1998 19.6 GT40
                    Just had a similar problem when i replaced my battery....the key is that you do not hear the fuel pump priming. In the battery box is a 50 amp slow blow fuse. Make sure that it has a good connection. When i replaced my battery i simply jarred that fuse connection and it came loose, also inside the fuse connection corroded and needed to be cleaned out. i would check that fuse and and fuse connection.....easy fix if that is all that it is
                    • JayG80
                      • Dec 2006
                      • 224
                      • Santa Fe, TX
                      • 2007 Ski Nautique Sold 2002 Ski Nautique
                      Finnz this is a older posts that talks about retrofit of 50 amp fuse - see #4.
                      http://www.planetnautique.com/vb5/fo...-to-20-minutes
                      • rbalan
                        • 328
                        • Georgia
                        • 2002 SANTE
                        Finnz, I'm not sure what fuse you are referring to nor battery box. My battery is up in the nose, there is an inline fuse close to the battery but I'm pretty sure it's for the control panel. Maybe that's a difference between mine and a pre 2000.
                        I'm headed to have the battery checked, I just played around with the keypad connection and there seems to be no problems there. I did notice that when pressing the start button there is a sound/click coming from under the dash/breaker box so that leans me away from thinking it's the keypad. There's just nothing that happens under the doghouse other than perfect pass activating.
                        • rbalan
                          • 328
                          • Georgia
                          • 2002 SANTE
                          Well the battery checks out, so I guess I will be checking all my grounds next.
                          • rbalan
                            • 328
                            • Georgia
                            • 2002 SANTE
                            Updating where I'm at now, battery checks out, 12.2 volts to new solenoid, starter works (bench test), power to breaker box under dash, and lanyard checks out. I think the only sound I am getting is coming from maybe a breaker on the back side of motor. It will sometimes make 1 click when pushing the start button then nothing, also still nothing from the starter or any fuel priming noises. So I'm at point now where it could be fuel relays, pcm, keypad (I do get a consistent faint noise behind the dash when pushing start), breaker panel under dash), or who knows. I'm not sure what to try next.
                            • natebrannon
                              • May 2025
                              • 3
                              • Salt Lake City, UT
                              • 1999 Air Nautque
                              I guess I’m 10 years late to the game. Did you figure out the problem? I’m going through the same thing on my 99 Air.
