Hi:
I have a 2012 210 with LINC 2.0 with all the current software updates. I have been experiencing this intermittent issue for over a year now.
1. Battery selector off or "0" when not in use
2. Battery selector to "1+2" when in boat
3. Enter code and start, LINC boots right up.
4. Hit "START" and nothing. Literally no attempt at all for the engine to start.
5. Sometimes and only sometimes, if I turn off LINC and re-do start-up procedure it starts strong.
6. Sometimes it won't start at all.
Any ideas would be appreciated.
Best
Best
). The start button will work even before the system is fully booted up. Have you covered all the basics...tether is attached and firm, throttle is in neutral (sometimes the driver chair bumps the throttle or sometimes it helps to slightly wiggle it in the neutral position just in case there is a bad connection), etc.
