Help me put please. The boat has always stated great and a couple day ago it did nothing when i hit the start button. If i jump the starter out it will run fine. There is a white wire that goes to the terminal that i am jumping out on the starter. When i hit the start button there is no power to it... What could be doing this. I followed the white wire from the starter and it goes to a small cube with four wires. On the other end the start button it does click and seem to be working fine. The pme box also clicks so i think it is something else. Has anyone else ever had this problem?
PME box clicks?? so the breaker has tripped??? i would check for power from the switch to the PME, that would eliminate a loose connection there.
Check the PCM service manual.... but could be relay for the starter. should be able to get power from the PME to the starter relay.
Most of the troubleshooting involves half-splitting to see where you are losing the "signal".
http://www.planetnautique.com/Correc...MEFIManual.pdf
It clicks the same way with all the other switches. I am pretty sure it is the relay inside working. I am 90% sure it is not the pmc.
