just curious,
I installed a new set of aluminum heads on our 95 SS. The orginal heads had a lot of ground wires running to them. Do I need to run the grounds the same on the aluminum ones? Im going through ignitiin modules for some reason after the swap, cant figure out why orther than maybe a grounding issue.
Thanks
Thanks
