New to me, used boat, had engine replaced about 20 hours ago. First few trips everything was great, absolutely no issues, then last weekend on Friday noticed a little oil in the bilge at the launch ramp, not much, checked the dipstick- all good, kind of assumed it was the first time there was a lot of water in the blige- water is finally warm that ppl are getting in and out and swimming a lot, so I thought maybe it was hidden in the bow or something, just finally sloshed back to where I could see it.
Day 2 ran great, but that night at the launch ramp significantly more oil loss, clearly something is up. Check dipstick, very bottom of range, but still good.
Added a quart next morning, ran it half day, by then Oil pressure warning had come on, and bilge was even more full of oil... quarts. Dipstick almost dry, crawled in the engine compartment, looks like this. No signs of oil until the back of the boat- ie the front of the engine where the belts are. First thing I noticed is that it had gotten on the belts and consequently been sprayed all over the engine dividers. At a closer look, I saw one hose that looked like the clamp wasn't tight enough and that oil was leaking from it (see red arrows in photo) but this doesn't appear to be an oil line so I think it is coming from somewhere above this hose/clamp maybe?
My first thought was maybe the head gaskets weren't tight enough after the rebuild and leaking there, but seeing where most of the oil is in the back and not anywhere along the sides I'm starting to think maybe timing gasket? Bored at work far away from the boat but thought I'd bounce my thoughts off all of you, anyone with ideas or a similar experience i'd love to hear your thoughts, thank you.
