New to the Site but I have been through many of the threads researching especially related to the fuel control Cell. I'm stuck so please help me get my boat running, Thanks in advance
Boat: 2005 210 Team Edition
Engine: PCM 330
Back Story: I bought the boat about a month ago. It had been sitting unused for about a year. The previous owner wanted to water test it before I met to test drive it the boat. When I got there it wasn’t running. The old owner said she ran the boat and took it around the lake for a cruise. It started to die and shut off. She restarted it and headed back to the dock and it kept dying and increasingly was hard to start. The boat eventually would not restart and had to get towed in. Needless to say I got there helped put it on the trailer and bought the boat……. I did the work below and still cannot get the boat to run other than briefly starting for a second.
Work so far
Current State: After changing all the parts above the boat started and ran for about 15 seconds then dies again. It sputtered and died. The boat would not restart. I had it on the trailer and tried to start it after sitting for a week and it fired up instantly, I shut it down after about 3 seconds because I didn’t have it in the water. The next day I go to take it to the lake to test it and again fire it up instantly on the trailer run it for 3 seconds and shut it down. It started and sounded perfect (I ride a friend’s 210 with a PCM 330 regularly it sounded identical) and I shut it down after a second or two. I took it to the lake, put it in the water and it started instantly and ran for 10 seconds and shut off. It sounded like it was shut off when it died. The boat would not restart after multiple attempts.
I’m at a loss for what the problem might be, any help would be greatly appreciated! Thanks
Engine: PCM 330
Work so far
- New high pressure fuel pump (verified 52ish + PSI at the Rail)
- New fuel filter
- New distributor cap and Rotor (verified spark at one of the plugs with a tester)
- Gas tank Drained of old gas and new gas put in, added 2 cans of seafoam
- Kill switch (verified that when the clip is in placed fuel pump kicks on)
- LP pump was supposedly replace last year (I can hear it kick on when I cycle the ignition)
- Battery’s charged up
