Repair for Dead Gauges on 2003-2006 Nautiques Caused by Bad Faria Gateway
This is a sticky topic.
  • wakejunky
    replied
    I wonder if there is a way to tap PP sensor and feed it into the gateway or bypass the gateway to still get the speedo to work.
    Leave a comment:
  • Indyxc
    replied
    Has anyone figured out exactly what seal fails, and can it be proactively replaced once in a while to prevent this from occurring?
    Thanks
    Leave a comment:
  • Kmayotte
    replied
    Thank you for making this sticky post! My gauges went dead shortly after pulling my '04 from winterization. I pulled the gateway box apart and water just poured out of it. The circuit board was a mess and FULL of corrosion. Clearly this has been an issue for some time and it's finally died, somewhat surprised it took this long. I cleaned the board up as best I could dried it out and reinstalled to no avail. Gauges still dead. At least I can still operate the boat and perfect pass works. Time to start researching my next step for repair.
    Has anyone had any luck finding a gateway box after market from a junk boat?? I'm ok with different dash gauges but I'd hate to lose the air/water temp, engine info and depth on the digital gauge.
    Leave a comment:
  • emjayem
    replied
    Originally posted by emjayem
    so.... i removed my gateway box to inspect it and remove the pitot tubes from it to prevent the water damage possibilty and now my temp gauge and hour meter and tach gauges are inop.
    The gateway box seemed fine, i didnt get it open because it seemed very sealed and stuck so i did not want to force it, so i re-installed the box and triple checked the connectors. Got it out on the water and now have these issues, I did notice that the low RPM red light would still come on at closed throttle as designed.....I have had no problems until now with my gauges and no signs of water in the box from what I could tell.
    any thoughts on what may have happened?
    Figured it out... there are 3 triangular connector bungs on the box, 2 of which are unused and all the same shape. I plugged it in the wrong one.....:rolleyes:
    Leave a comment:
  • jkallen21
    replied
    Originally posted by mr_454ss View Post
    The next challenge is going to see if the wife notices the new gauges or not. She already told me we don't need to spend money on the boat.....
    Did you laugh? maybe just a little (when she wasn't looking)?
    Leave a comment:
  • emjayem
    replied
    Leave a comment:
  • mr_454ss
    replied
    Leave a comment:
  • obd666
    replied
    After getting into my gateway box and not seeing any signs of water damage I decided to buy the 2009-on limited/team gauges.
    good deal, post a pic when you're done. i am interested to see how they look in these dashes.
    Leave a comment:
  • mr_454ss
    replied
    After getting into my gateway box and not seeing any signs of water damage I decided to buy the 2009-on limited/team gauges. It is entirely possible a 10 year old gauge would just stop working..... I installed them today and the fuel and volt gauges are working! I'm hoping and fairly confident the engine temp and oil pressure will work also. Now I just need to upgrade the Speedo and Tachometer to complete my dash.
    Leave a comment:
  • Quinner
    replied
    TJ, in theory if the boat will never see freezing temps then no it should not be an issue however if you drain/winterize the motor you should probably disconnect your pitot line's as well. Depending on how accessible your gateway is, removing the pitot lines is an easy task.
    Leave a comment:
  • Beach-TJ
    replied
    Originally posted by Quinner View Post
    .....One thing you may want to add is a known cause of the water backing up is freezing/ice.....
    Quinner, so this shouldn't be an issue for a boat that's never seen freezing temps? I'm wondering if I should worry about disconnecting the pilot tubes proactively or if it's not a concern since my boat has always been stored inside during the winter and never experienced freezing temps.
    Leave a comment:
  • Quinner
    replied
    Jeff & Gator
    One thing you may want to add is a known cause of the water backing up is freezing/ice. Pitot's are supposed to be self draining but apparently do not always function correctly, if not drained and freeze occurs water will back up on the circuit boards. As a result winterization should include disconnecting the pitot hose connections at the gateway during layup, I also remove my gateway box and store it in the house during layup.
    Leave a comment:
  • gatorgates
    replied
    NautiqueJeff - thanks for the shout out. I hope this helps somebody.
    By disconnecting the two pitot tubes, you will lose nothing but the speed information. All of the other functions in the digital part of the speedo (e.g. water temp, air temp, etc) will continue to work as normal. And yeah, I did reseal the box with a bead of silicone. Not sure why, but since it was sealed when I took it apart, and since the trunk is pretty humid, I figured why not?
    This fix worked for me because I am pretty sure that the water was in the box for only a few days. All the gauges worked fine when I put her away for the winter and worked great when I fired her up in the spring, but gorped out the first time I got up to speed (and increased the pressure in the tubes). I tore into the box 3 days later.
    Leave a comment:
  • obd666
    replied
    was just in the manual so thought i would add this ... doesn't look like i would lose any functionality beyond the speedometer
Name:	pitot tubes to faria gateway.PNG
    Leave a comment:
  • mr_454ss
    replied
    Yesterday I got into my gateway box and everything looked good. No water in the gateway box and no traces of water. I cleaned everything up as described above. After all that my oil, fuel, and volt gauge still are not functioning. I can see everything on the digital readout so I guess I'm stuck scrolling for now. I'm going to buy new gauges and see if that fixes the problem.
    I did add some pneumatic tubing to the pitot tubes. I routed the tubing in a swooping "S" on its side. I filled the low valley with mineral oil. My thoughts are water will push on the oil and the oil will push air to the transducers. I haven't taken the boat out yet to test my theory but I will report back.
    Leave a comment:
