1995 Sport with Hard Steering
  • KTompkins
    • Aug 2004
    • 34
    • Corpus Christi, TX
    • Current boat: 2009 210 SANTE Second boat: 1995 Sport Nautique First boat: 1982 2001
    My 1995 Sport needs some help with its steering. I noticed that it was getting pretty hard toward the end of last season and now I need to get it fixed. Should I start with the Cable? The rudder looks fine, and I don't think the seal is leaking. Boat has 800+hrs on it.
    Old Boat: 1982 2001
    Old Boat: 1995 Sport Nautique
    New Boat: 2009 SANTE 210
  • wakejunky
    • 679
    • Ca
    • 2003 SAN
    RE: 1995 Sport with Hard Steering
    You can try disconnecting the cable at the tiller and see if the rudder is stiff or the cable. I'd be 10:1 that you'll need to replace your cable. Not a hard job but, not an easy job.
    Chris
    • Sbt3
      • Dec 2004
      • 164
      • Okauchee Wisconsin
      my guess would also be cable. I just ordered one this weekend for my 97 supersport
      • slob02
        • Sep 2003
        • 333
        I agree with all above...................It will be like a new!
        2008 Super Air 210 Team
        2004 AIR 206 Team
        1997 Ski Nautique 196
        1993 Ski Nautique SNOB
        • KTompkins
          • Aug 2004
          • 34
          Thanks, the Tech at DIM said the same thing. But looks like I will need to order the cable from Correct Craft. I better hurry, the water getting tolerable.
          Old Boat: 1982 2001
          • ag4ever
            • Feb 2004
            • 1180
            Some have just used the longer cable with a creative routing job to take up the excess. That would save you some time and money, or call Houston Watersports Complex (Houston) or Sail and Ski (Austin and San Antonio) to see if they have one in stock.
              • 16872
              Or you could order it from White Lake and take advantage of the 10% PlanetNautique discount. The price for the cable you need is $169 before the discount, and since the order is over $100, you'll get a free Nautique shirt. Click on the White Lake banner at the top of this site for more information.
              • jhiestand
                • 786
                • Columbus, Ohio
                • 08 Super Air 210
                Does it steer hard all the time, or only while the boat is on plane? If it only steers hard on plane it's most likely your rudder assembly needs greased. There's a grease zirk on the rearside of the rudder housing that is difficult to see, but shooting it full will be night/day. At least, on my '94 there was a zirk back there.
                If it's steering hard all the time, then it's most likely the cable.
                '08 Super Air Nautique 210
                • 97sport
                  • Mar 2005
                  • 78
                  • Youngstown, Ohio
                  Still looking for the grease zerk on my 97 sport. Had the rear seat out several times and still can't find it.
                  • jhiestand
                    • 786
                    • Columbus, Ohio
                    • 08 Super Air 210
                    I know CC changed it at one point since my 01 doesn't have one. However, my 94 did and it was pointed toward the transom, which made it difficult to find unless you knew it was back there.
                    • KTompkins
                      • Aug 2004
                      • 34
                      Well I made it to the boat barn and disconnected the steering cable from the rudder and guess what? The cable is the problem, in fact it feels worse much worse than it did 4 months ago. So I'm going to call White Lake, get a cable and a T-shirt. I also notice that the rudder has a little wobble to it. In addition when I move the rudder back and forth it feels like metal on metal. Instead of moving smoothly, it moves like bad breaks feel (I'm at a loss for adjectives). The rudder moves easily though. I'll talk to SKIDIM, but I'll bet I need to replace the packing. Oh and I couldn't feel a zerk but thats a pretty good reach to the rudder assembly and I don't know that I could grease it if it did have one.
                      Thanks for all the help.
                      Old Boat: 1982 2001
                      • peteSki
                        • Mar 2005
                        • 232
                        • Ottawa, On, Canada
                        • 2005 Sport Nautique 216 Previous: 1997 Ski Nautique
                        The steering on my 97 Ski is starting to get hard, but tends to loosen up after use.
                        Is there a way to lubricate the steering cable as a quick fix until a new one can be installed?
                        Pete
                        • KTompkins
                          • Aug 2004
                          • 34
                          No, according to SKIDIM a little play in the rudder is in the design. In fact the boat should pull to starboard if on a plane and the wheel is handsfree. Has something to do with keeping her straight down the boat bouys in the slalom course. I never regret calling those guys before I get too excited and cause myself more work and money than I need.
                          Oh and I ordered the cable from White Lake so I'll be getting a cable and T-shirt in a couple days.
                          Old Boat: 1982 2001
                          • foiltravis
                            • 15
                            • Austin, Texas
                            Pete: My 1998 Ski Nautique started steering hard and sounds similar to yours, it would get easier to steer as I drove it. I replaced the steering cable and the problem was still there. I ended up dropping the rudder out the bottom and upon cleaning everything up found that the rudder shaft and rudder box had some scoring (not a lot). I cleaned both up with some fine sandpaper, relubed everything and put it back together, steers like new. I sure wish Correct Craft had put a grease zerk in the rudder box. This was not really a hard job to do, I had to slide the boat back a bit to get the rudder to clear the trailer (I put it in the lake to do this) then I simply paid attention to how everything came apart. Oh, by the way to get the rudder out I had to remove the gas tank.
                            Larry
                            • peteSki
                              • Mar 2005
                              • 232
                              Thanks Larry, I'll disconnect the cable from the rudder and see if the wheel is still hard to turn to determine if it's the cable or the rudder.
                              Pete
