Did a compression test on my 1995 SN with Ford 351, results were all cylinders between 130 - 140 psi. Is this considered good. I guess a lot depends on the gage accuracy, at least all cylinders came in approx same readings.
RE: Compression test
how hard is it do do a compression test yourself? whats the cost of the tool(s)?
All you need is a compression guage. Disconnect the main electric going to the plugs. Take out one plug, screw in the compression guage and turn the motor over a few revolutions. Take a reading for every cylinder and pray that they are all about the same.
Re: RE: Compression test
10% is a pretty standard variation through out engines. A dealer told me on these as long as you're not more than 30psi difference you're fine. That is a substantial number, but apparently it's ok.Originally posted by surroundsound64+ or - 10% or 30psi is acceptable. And it's always a little more accurate when you do it with a warm engine. You'll get lower compression on a cold engine due to blow by.
Either way, dwsa's compression is good.2018 SAN 230
1981 Ski Nautique
Sold - 2011 Sport 200V
Sold - 2000 SAN
ryan, the tester will run you around +- $25.00, and checking is just as ffmedic described.how hard is it do do a compression test yourself? whats the cost of the tool(s)?
