No nothing was damaged. Well a little bit of my ego. And I lost an hour and a half of my life, never to get back.
This year recommissioning the boat, I could not get it to suck in any water. Went back under the boat made sure gizmo was on. Took of strainer it was dry. yada yada yada.
An hour and half later, I am like, what has changed since last spring? I added a heater. Well the air in the heater lines is to much for the sea water pump to over come and pull water through. So after taking the pump apart, replacing the impeller I toasted. All I had to do was pinch the heater hoses (taking the heater loop out of the equation), and to do that my face is 6 inches from the strainer. Voila I can watch the water get sucked into the strainer into the system, and out the boat.
Has this happened to anyone else? Or am I the only stupid one on the forum. Time to get some shut-offs for the heater....
