I took my boat into theWest Coat Correct Caft this week. Its a Air Nautique with 502 hrs on it. PCM 5.8 GT-40. The service tech (Mark R) noticed that the heat riser's look like they are starting to leak from the outside. He said that this is comon with this motor and that PCM has made 3 differnt versions of heat riser gaskets to try and fix this problem. He said my boat came with the 2nd version of the gaskets and he will install the very latest version. (not under warranty) :???: When he took the heat risers off he noticed that the inner gasket to the heat risers also has started to leak. This is not common and that when the inner gasket leaks it causes water to collect into the cylinder's. This can be very bad. He said when he removed the spark plugs he noticed that there was a bit of rust on one plugs and that told him that there was water in a cylinder at one time or another. They looked in the cylinder and everything is ok no damage but this could have been a much larger problem. if I was to have left the boat unfixed over the winter time, That rust could have built up in the cylinder along with not using the boat in the winter and cause a big problem come spring time when you would start to use the boat again. It was kind of by luck that we caught this problem take a look at you motor and see if the outer gasket is starting to fail. You will know if You can see some rust and water spots where the exhaust manafold meets the heat riser. Thats a good sighn somthing is fishy.
This along with some other things he found might be the cause of my mistrey Motor Quits problem?
