Does anyone have a source for new ballast sending units. I have a '99 Super Sport with the factory ballast tanks, and both sending units are bad. SECC wants $160 per ballast sender, I have check both gauges (by disconnecting and grounding the sender wire) and they seem to be working. They say the senders are 10-240ohm, which is the same as early ford fuel senders. I didnt know if anyone has found an alternative to the expensive senders. I cant see any manufactures name on either sender. Thanks for the help, Newbee :grin: Nautique Owner
-Lee
-Lee
