I have a 94 sport with the 5.8 pro boss and pro-tec EMS. I went to start up last week and the engine would turn but would not fire! I popped the top and checked for fuel and any fuel line blockage. No problem there. I then pulled a couple of the plugs and found only normal wear. seeing no apparent problems I tried firing the engine up again and after several more attempts the engine finally fired up. I let it run in idle for about 90 seconds without any problems. I then dis-engaged the shaft and throttled it up slowly. at about 2200 rpm the engine sputtered and died. I was unsucessful in getting to fire up again. I have since checked for spark and bottom line is that there is no spark to any of the plugs.
The problems apparently lies somewhere within the nebulous Pro-tec EMS. I am seriously considering the shotgun approach of a retro fit kit taking it from an EMS to a distributed system but would like to avoid such a drastic measure.
any suggestions or thoughts would be greatly appreciated. If anyone knows where I can get the retro kit cheap or equivalent parts that information would be appreciated as well. (best price i've seen is $454 @ skidim.)
Thanks.
Thanks.
