does anyone recommend a good way to winterize the ballast tanks
RE: winterizeing water tanks
Most of the CC tanks have a red drain plug at the very bottom on the back of the tank. Just drain the water out of that hole, and be sure to pull the hoses off of your pumps to get all water out of them as well.Please do not PM me directly asking for advice on how to repair your boat. While I would love to help everyone, I simply do not have time to respond to all of the inquiries. Please post your questions on the forum, so that all of our members have a chance to answer.
nautiquefan,
I use compressed air (LOW PRESSURE) to blow the water out of the pumps through the hull fittings and then add a small amount of RV antifreeze in the tank (through the vent) and in the pump (through the pump out in the side). On the 216, the tank drains are at the end of red hoses at the front of the engine.
I try to blow out and drain the tanks between lakes also. This is to keep from moving "foriegn" species around. I recommend everyone do this. These foreign species (mill foil, zebra mussles, etc.) are killing some lakes and rivers. Enough SOAP box.
I also blow
I feel for you guys who own boats in cold weather climates. Seems like there is a lot of added work in getting the boat through the winter.
Out here winterizing your boat means putting away the bimini, throwing in an extra sweatshirt, and turning on the heater when you use it. 8-)
BKH2001 Super Air
