05’ 206 Air w/330hp and Perfect Pass WB Pro, issues with high idle and “hammer down” loss of throttle.
Intermittent high idle issue, dealer suggested removing PCM decorative engine cover because of conflict with it and Perfect Pass cable, did not resolve?
Other condition is if you drop the throttle full the PP cable slacks out and you have little or no throttle?
Dealer has not come up with a solution at this point. Anyone w/similar problem and/or solution??
