Hello there. I have a 2002 SANTE and I was at the lake 2 weeks ago and had a problem starting my boat...wondering if anyone has any ideas? I have narrowed the problem down a little but some more input can always help. I was there trying to start my boat and it would not spin the motor- the starter would click once when you push and hold the keypad push button. I then proceeded to check my safety wrist band switch pin right next to the throttle. That was in place. I then check the battery power...with 9 Optima batteries at full charge this was not an issue. I then went to check the wires at the starter and just barely touched them. It suprised me when I tried again it started perfectly! I would think: starter relay, wires at the starter are loose, or my starter is going out. I called the local dealer and the mechanic there says it sounds like the starter relay is going out......that he has seen this problem with many other V drive Nautiques and its a quick fix. I would hope that it would only be a relay because that starter is in a tight area to replace. Any idea where this relay is located? Any pictures to help out???????
thanks for any help!
Harold.
Harold.
