Lift shocks for 97 super rear hatch
  • Brichter14
    • Jun 2013
    • 535
    • Central Illinois
    My electric actuator stopped working and i never really liked it in the first place so i want to get some shocks to hold it up. I have seen it done in the past so does anybody have some reccomendations??
  • scarbs
    • Aug 2009
    • 450
    • Arizona
    • 2017 G23
    I did it...here's the link:
    http://www.planetnautique.com/vb3/sh...ocks-and-latch
    2017 G23
    2012 210 TE
    1999 SAN
    1995 Sport
    1991 Sport
    • s_kelley2000
      • 1589
      • Fort Meadow Recevoir
      • Mass
      My actuator has acted up a couple of times over the past 2 seasons. Both times the fix was tightening a loose connection or cleaning a dirty connection on one of the two relays. You may want to check those if you haven't already.
      But I agree that adding lift shocks like Scarbs did is a great improvement. The actuator robs tons of space in that locker and make it a pain to get to the block drain, water pump, trans cooler or anything else on that side. But I do enjoy the cool factor and getting the ooh and ahs whenever a newbie sees it lift haha.
      Shawn
      2012 Blue Metal Flake SAN 230
      • charlesml3
        • Jan 2008
        • 2482
        • Lake Gaston, NC
        • 2022 G23
        Gang,
        What you're calling "shocks" are not shocks at all. They're Gas Springs. Lots of people mistakenly call them "shocks" because they sorta resemble shock absorbors on a car. They're gas springs. http://en.wikipedia.org/wiki/Gas_spring
        • Brichter14
          • Jun 2013
          • 535
          • Central Illinois
          What mounting brackets did u use for the springs scarbs?
          • scarbs
            • Aug 2009
            • 450
            • Arizona
            • 2017 G23
            Just standard brackets off of eBay--one for each end of each shock. PM me your email and I can send better photos of the brackets, etc.
            2017 G23
            2012 210 TE
            1999 SAN
            1995 Sport
            1991 Sport
            • Brichter14
              • Jun 2013
              • 535
              • Central Illinois
              Would it be possble to attach the springs to the outside? Like this?
              • scarbs
                • Aug 2009
                • 450
                • Arizona
                • 2017 G23
                Probably, but you'd have to get a different type of bracket. And if you mount it to the fiberglass only, you might put undue pressure on the gel that may cause cracking. But a bracket like this (only turned sideways) should work if you want to go that route:
                2017 G23
                2012 210 TE
                1999 SAN
                1995 Sport
                1991 Sport
                • Brichter14
                  • Jun 2013
                  • 535
                  • Central Illinois
                  Thats really helpful scarbs thanks. I think i will try it on the outside and if it doesnt work ill just try to support the middle.
                  • Brichter14
                    • Jun 2013
                    • 535
                    • Central Illinois
                    Which one to buy?
                    • scarbs
                      • Aug 2009
                      • 450
                      • Arizona
                      • 2017 G23
                      I think any of them would work. But I'd go with option number one.
                      2017 G23
                      2012 210 TE
                      1999 SAN
                      1995 Sport
                      1991 Sport
                      • EchoLodge
                        • Jan 2004
                        • 616
                        • Huntington Beach, CA
                        • 99 Super Sport
                        Keep us posted if your gas shock method works Brich.... I have been talking with Scarbs about his method. Want to do something this winter.
                        sigpic
