V-drive and transmission oil
  • Fred
    • Dec 2010
    • 4
    • Lausanne, Switzerland
    • 2004 SUPER AIR 210
    Hello,
    I have an Air Nautique 210, years 2004, with PCM330 and V-Drive.
    I'm not sure I understand which oil must be used for V-Drive and transmission.
    Can I fill the V-Drive and transmission with Dexron III (ATF) ? Or transmission is another oil ?
    Sorry for my english.
    Thank you for help.
    Fred.
  • ski4evr
    • May 2010
    • 613
    • Bowling Green, KY
    • 2005 SV 211
    ATF for transmission, and 30 wt. engine oil for vdrive
    2005 SV-211
    • beach
      • Jul 2010
      • 245
      • Alabama
      • 2003 SAN 210
      Dextrin III is no longer available. I read that Dex/Merc is the closest to Dextron III so that is what I use. I also read that the 30w oil should be non detergent, so that is what I use.
      • Fred
        • Dec 2010
        • 4
        Here in Switzerland i have no problem for find Dexron III.
        http://motorex.com/index.cfm?oid=116...eintragId=7451
        So can I fill Transmission and V-Drive with this ?
          The V-drive needs 30 W engine oil. Do not use ATF in the V-drive.
          • Fred
            • Dec 2010
            • 4
            ok thank you.
