Water temp was 53 and air temp was 55. The engine was running at 158 not sure if the thermostate ever opened up. Usually it will run right at 160. I put in a new impeller the middle of last season. I have noticed that the gasket at the top of the exhaust manifolds is leaking just a touch of water. Could this cause that?
It is normal. Gasoline is a hydrocarbon. Burning it creates water vapor, and carbon dioxide, and some other gasses. Burning gasoline, or any other fuel creates heat. Your engine uses lake water to absorb some of that heat. That makes hot water, and some of it evaporates in the heat from the engine exhaust.
If the air temperature is close to the dew point, and it commonly is this time of year, all the extra water vapor from the engine makes fog, because when the exhaust is cooled to ambient temperature by the air and lake water, the exhaust is well below the dew point.
You do not notice the exhaust fog in the summer, because the dew point of the exhaust is above the ambient temperature.
Originally posted by DanielC View PostIt is normal. Gasoline is a hydrocarbon. Burning it creates water vapor, and carbon dioxide, and some other gasses. Burning gasoline, or any other fuel creates heat. Your engine uses lake water to absorb some of that heat. That makes hot water, and some of it evaporates in the heat from the engine exhaust.
Completely agree. Normal in colder temperatures.
