If you stick your head in the bow, you can see the light of the glass line that holds the cooler in.
After scouring the garage and shop for the perfect tool, I settled on the dremel with a tile cutting bit (used 2) took my time and cut away from inside the cooler. Got it out through the bow opening in one piece, and then sanded the inside cut edge smooth. There is pvc pipe with cable that is glassed to the deck, and I sanded all of that smooth as well. A putty knife worked really well on cleaning off the foam, and then layed the new carpet on the inside of the deck (wall?). Really happy with the space it opened up!
