I'm relative green when it comes to surge brakes. The rear axle on my trailer has disk brakes. Got to the ramp today and when I was unhooking the boat I felt the heat coming off of both rear wheels. Both being hot leads me to believe it's a wheel cylinder sticking and not a caliper issue. Is there something else in the system I should look at before replacing that? (Fluid level was good and all zerks are greased.)
It has reverse lockout but seeing as how it got hot on the drive there, and not having driven there in reverse, leads me to believe it has nothing to do with the reverse lockout.
Oh, and by hot, I mean HOT! The caps on the bearings were popping out and I could splash water on the wheel and it would boil. When I got home I pointed my gun at it and saw well over 200 degrees (makes sense, water boils at 212...)
