Hull cracked at rudder port
  • dereklowery
    • Aug 2014
    • 12
    Help.. The hull is cracked where the rudder port is mounted . Is there a easy way repair.?
  • dereklowery
    • Aug 2014
    • 12
    • core-rider
      • Feb 2004
      • 1360
      • Huntsville, AL
      • 2003 Black SANTE
      I could be wrong but I don't think that crack is in the gelcoat. I think that is the sealant they use to help make it watertight around the rudder and hull. I've seen the caulking pull away like that before and look like cracks. If that is your case, just remove the old caulk and re-seal it with new. Something like 3M 5200 or 4200 will do the trick.
      Jason
      All black 2003 SANTE
      -- Southern Fried --
      • dereklowery
        • Aug 2014
        • 12
        Thanks , but its defiantly cracked I can move the rudder back and forth about 3". Haven't taken it apart yet .
        • dereklowery
          • Aug 2014
          • 12
          Has anyone seen the hull cracked here ? Is it common .. I am new inboard boat world .. Its on a 1990 ski nautique
          • 81nautique
            • Feb 2006
            • 257
            • Big Rock, Illinois
            • 2012 200 Sport 1956 Correct Craft Collegian Past boats 1955 Correct Craft Hurricane 81 Anniversary Nautique 1960 GlassCraft Ski Nautique #1
            Is this boat new to you? Back and forth 3" sounds like the rudder took a hit, I think you need to have a dealer look at it and really see whats going on. This could be potentially dangerous situation for you, make sure the rudder itself doesn't have any damage.
            • dereklowery
              • Aug 2014
              • 12
              Yes its new to me . I have had it out about 5 times and I noticed last time out the rudder needed to be repacked and the hull flexed a little . It looks like it has been patched before on the inside
              • ddipert
                • Nov 2013
                • 116
                • Mebane NC
                • 2010 SANTE 230
                If it's moving that much I would be checking the inside of hull for damage. Could be as simple as the bolts are all loose, but could also need a fiberglass repair. Without further investigation it's all a guess.
                • chris196
                  • Mar 2007
                  • 223
                  You might have a cracked hull, but I can't see it in that picture.
                  You really need to either start taking things apart to have a look or bring it to a professional.
                  Not to offend, but how handy are you and have you dealt with other diagnosis and fixes of things in the past?
                  • dereklowery
                    • Aug 2014
                    • 12
                    No offence taken i have looked on the inside of the hull and it has a large bead of silicone . Also when I move the rudder back and forth it sounds like the fiberglass is cracked , the bolts are tight I had just tightened them last weekend . I am 99% positive the fiberglass is cracked .. Just wondering how hard it would be to patch it ? Or if anyone has ever repaired this part of the hull.. I have diagnosed and repaired a lot of parts throughout the boat with the help of post already on this forum . Thanks for all the help
                    • dereklowery
                      • Aug 2014
                      • 12
                      Also checked the rudder and no sign of hitting anything
                      • atolman
                        • Apr 2014
                        • 20
                        • Charlotte NC
                        • 1991 Sport Nautique
                        You'll need to have the rudder removed and then get some fiberglass work done. I hit a rock last year and it cracked there and shoved the whole rudder box up into the hull. Pulled everything and my fiberglass guy did a great job with the repair. Been working great all summer.
                        • dereklowery
                          • Aug 2014
                          • 12
                          Ok that's what I was thinking thanks
                          • dereklowery
                            • Aug 2014
                            • 12
                            Here are some more pics . it is defiantly cracked on 3 sides and the gel coat . It has been patched before .
ID:	368733 Click image for larger version
ID:	368734 Click image for larger version
ID:	368735 Click image for larger version
                            • ddipert
                              • Nov 2013
                              • 116
                              • Mebane NC
                              • 2010 SANTE 230
                              Whomever repaired it before did a poor job at best. Shouldn't be a difficult repair for any fiber glass person, I'd DYI if you have worked with fiberglass before. To me it looks like the last repair was done so they could sell the boat.
