okay, so my 2003 SAN has tanks in the back with 400 fat sacs on top. To pump into these I have two valves that have a long lever that sticks up to just below the sundeck pad in front of the motor and I turn it to "open" to pump and then "close" to ride once they are full. This isn't a huge deal but it is a pain to open and close. Unfortunately the "close" does not keep the water from pumping in when we are riding and I constantly end up pumping water out to keep my fat sac from busting out the top of the compartment as it has done before and it seems dangerously close to breaking my electric hatch releases (it is a limited and so these are electric instead of manual) I can't find any easy fixes that mention an 03 and I don't know what years have the same ballast set ups. I don't have any problems with my front ballast as it overflows into a bag the front seats (v shaped) and then that just over flows out the side but there's not enough pressure while driving to overfill this one.
in summary:
is there a quick fix for the leaking valves when driving?
Is there a way to make these valves automatic to be able to control them from the drivers seat?
Thanks to all you ballast gurus. This is my first boat and I'm still new at all this.
in summary:
