I hit a floating log in shasta last week and it damaged my prop. Visually the prop looks fine but at speed the boat shakes a bit. Is there anywhere somebody can recommend a fix? I've got my spare on now so I'm not in a huge hurry. I'd like good work for a reasonable price.
RE: Prop fix in San DIego
very often u blended the pro shaft also after the prop hit the log,the shake if not from the prop,should be come from the little blended prop shaft, I hit stone one time last year and damaged the prop and shaft,I changed both. some shop can straigthen a blend shaft or repair prop,it may cost cheaper.
Call Eddie at San Diego Propellers in Spring Valley.......very good prices and a great turn around time.
He will go way out of his way to take care of you.
Tell him I sent you, he is a local rider and owns the shop.
Gramps
I'm hoping to get the boat back in the water this weekend with my spare prop and check the vibrations. Thanks for the tips. Looks like I'll be making a trip down to Spring Valley! Thanks Gramps/clubmyke.
