I'm a newbie and would really appreciate some seasoned veteran insight here....I recently purchased a 2008 SANTE 210 with the PCM 343. A few days ago, I had it out and was getting some higher than normal engine heat at startup and low speeds which made me think it was in need of a new impeller. At higher speed the engine cooled down and ran great, however idling later in the day and back to the dock, the engine temp began to climb again. I immediately replaced the impeller (the old one was in bad shape when i removed it) with a new one and have had it out twice since. Both times, upon startup, the boat engine heat climbed more than it should initially - enough that the SEE DEALER light was on and beeping at me. Then, after I turned off the engine and waited a few minutes, I started back up and immediately increased the speed some. The engine cooled down immediately and ran great. Even at idle speeds later in the day and returning to the dock both times (with the new impeller installed), there were no engine heat issues whatsoever. It was almost as if the new impeller needed to "seed" or "break in" a bit both times...
3 questions -
1. Anyone seen this before?
2. Is my assumption the new impeller needs a chance to be "broken in" accurate ?
2. If my assumption is accurate, how many times out will I need to do this before the new impeller gets working immediately upon startup?
Any insight is greatly appreciated.
3 questions -
