Any updates?
not yet. the dealer cant figure it out. theyve been working on it for hours, in the meantime im looking at this calm water out my window. very frustrating.
Mine came up with an overload detected to the port side, shuts off everything! No radio, courtesy lights, docking liters etc. funny, it worked all day and threw this curve ball on a night ride at idle
Sent from my iPad using Tapatalk2013 SANTE 210
2011 Sport 200 V
1994 Bimini Skier Pro 190
1986 Master Craft Pro Star 190
Hello all who are following this thread. It sounds like the LINC software somehow became corrupted, possibly from the boat sitting over the winter. Wizard lakes had it under control pretty quickly. Reloading the software got everything working normally, but brings up something to look into deeper.
4th ski-doo,
Are you sure that the port NSS was the only fault? It should only disable the port NSS channel not the whole accessory circuit. It sounds like you might have something else going on (if you had a fault on the accessory circuit the right LED would be blinking on your keypad).
Adam- it's awesome you are on here. Welcome !
were you at the Dallas boat show?2019 G23 450
2014 G23 550
2013 G23 450
2011 Malibu Wakesetter 247
2007 Yamaha AR210
well, got the boat back this eve. looks like the nss is working again. id really like to thank wizard lake and especially adam from correct craft. adam went way above for me. he called me at home, emailed a number of times and helped my dealer fix the problem. its because of people like adam that make cc a special brand. my kids am i are so excited to get on the water up here.
I'm having the same issue on my 2015 210. Buxton is coming out to the lake to check on it this week. In phone comes they seem to think it's the puck. Same as the OP, the screen says everything is working.
I've been watching this tread for the past couple weeks. I'm glad to see some recent activity and the possibility of it just being a software issue. I too had a fault code on my 2014 SAN 230 on the Starboard Side. The dealer was swamped and couldn'tcheck my boat in time for my big July 4th weekend so I held off. Still surfed by sacking the corner... Man I missed the NSS! I will be running it in to the dealer this comming week. Is there a technical bulletin out addressing this? Should I just have them flash the LINC with an update?
So I have noticed that it seems like my starboard NSS hasn't been working too well. From the post, it led me to look at the fault codes. Both the port and starboard wake plates had errors. I did a reset but have not tested yet. My question is, is there a way to test the NSS out of the water? I'd like to see the plates move myself to ensure they are moving correctly?
I haven't tried this, but I read somewhere (maybe a thread here on PN) that you can enable River Mode and set it to more than an 11mph offset. That way, the boat thinks it's already going 11mph and you can get the NSS tabs to deploy while you're sitting still. Can you try that and see if it works?Originally posted by jondavis08 View PostMy question is, is there a way to test the NSS out of the water? I'd like to see the plates move myself to ensure they are moving correctly?
-Charles
