Good Afternoon,
I have a 2003 226 Team Edition. The starboard ballast will pump a little bit of water in then stop. Center and port work fine. I can drain the small amount of water that fills in the Starboard as well. Any ideas of why it would fill a litttle then stop? i assume the pump is working, because it is pumping some water in and the drain pump works to get it back out? any thoughts/suggestions would be appreciated.
