I'm testing everything on the boat since I just got it and haven't been able to take it out yet. We plan on leaving it in the water in a slip for 3 nights next weekend. When I toggle the master switch under the dash to bilge only, nothing happens. However, when I toggle the switch to on and press the bilge pump button (only, keypad still turned off) the pumps work. This does not seem right. ( I pumped water into the bilge area with a garden hose for this test.)
It seems like someone has messed with the wiring so nothing happens when the master is to bilge only. Am I supposed to be able to turn on the bilge pumps via the soft key when the master is on and the keypad is off?
Thanks
2000san btw
Thanks
2000san btw
