Was going 38 MPH when out of no where started feeling a bad vibration slowed down and it went away speed up and came back. Anybody ever had this problem before?
Could be a number of different things. Check prop first as it is easiest. Could be cutlass bearing in the strut, move prop shaft aft of strut side to side and up and down. You should have little to no play in the bearing. Also, when was last time you had shaft alignment checked?2002 Ski Nautique 5.7 GM Apex
