2005 SANTE
330 PCM
First time in the water. Starts up fine, idles fine. Revs up fine... water cooling normal, but the oil gauge does not even move when you start the boat or ever. The 1200 RPM light comes on, but I assume the computer thinks there is a pressure problem with the oil since the gauge is not registering anything?
Idled and rev the RPMs around at the dock for 10 minutes. If I really had zero oil pressure, Id assume my engine would be banging around with no oil and Id hear it. (nothing by the way.. smooth)
So it leads to be believe... bad gauge or bad sender.. or is there some other known issue with the oil pressure on these boats?
Anything else I should look for folks or are my assumptions completely off and I have a different problem?
Thanks!
330 PCM
Thanks!
