I was running my boat last summer and ran it hot{270} I know wow that's hot.took it to the lake to kinda test it out last week, and I have a small miss under a load. also it was hard to start.i changed the plugs and the miss is gone
I have done a comp. check and number 3 has 9.5bls, all others have 109-126lbs. took off the heads expecting to find a blown head gasket{on the exhaust side} or a burnt valve I found neither of the 2. I have them at machine shop now. the "head" guy said the look good no sticking valves no bent or burnt valves. there checking to see if they are warped. if not there going to do a valve job on it, just cause its off the motor.... if it comes back not warped what could it be?..oh yeah while the heads were off i got the water out of them{from when i pulled the heads off} then sprayed with pm blaster to ensure no rust. the walls of the cyc. felt good no groves and the piston looked good no holes or chips. the pb blaster is still sitting in the cyc. today so it cant be a stuck ring or stuck piston.... what else could it be?
