I have a 2001 SAN with the 351 PCM Ford engine. Every once in a while when I try to start the engine I hear one click and the engine does not start. To start the boat I had to hook up the jumper cables. My first thought was a bad battery or connection. I took the Marine deep cycle Die Hard battery with 650 CCA amps to Sears and they said the battery is good. I also checked all of my cables and they look clean and tight. I then put a volt meter on the battery when it is in the boat and it reads 12.8V. When starting the engine it drops to 10.8V and quickly goes up after starting. When the engine is off and my stereo is on the battery stays steady at 12.55V.
Why does the engine not start occasionally? If you need more info to help me out than whats above please ask.
