Looking for some help folks!
Little background: I have a '94 5.8 HO Throttle body, about 540 hrs.
The issue: Sporatic. Drives me crazy. I'll come out of the hole quick, just get up on a plane, and it dies out completely. Now, it has always restarted after cranking a couple seconds. Sometimes I'll get up on a full plane and I'll be fine, bring it up to 35 and all of a sudden it'll hesitate and die out. Try pulling a skiier it'll work fine 5 times out of 10.
Here's whats been done: The EEM is in the trash so we can rule that out. That was last years issue. As you may know you can't get them anymore and they go out over time. We put a Mallery Distibutor back in it and it has run fine ever since. Tried running a can of dry gas in it, that seemed to help a little, but Friday night it acted up again and I'm still on that tank. It almost sounds like it's fuel related because it restarts everytime, but then again it could it be a bad coil?????
1. Do you think it could be the coil?
2. The fuel filter was replaced last fall so I don't think its that....
3. It has new plugs and i checked mostly off of my wire connections.
4. Is there such a thing as an accelerator pump in that carb that could be causing issues?
5. The carb was rebuilt last year and it seemed to be okay.
6. Vapor lock?
Any help would be great. It's driving me crazy. Thanks everyone, great website!!!!!
6. Vapor lock?
